OMG! 07 Horn is a joke!
Old Sep 5, 2007 | 06:13 PM
OTO27's Avatar
Default RE: OMG! 07 Horn is a joke!
Well its defenetly louder than my Lancer, it does sound high pitched but it makes my wife jump every time I honk when shes opening the garage door for me. So its good enough for me I guess [sm=badbadbad.gif]
Old Sep 5, 2007 | 06:57 PM
rdenis's Avatar
For a Japanese horn its not bad but if you want to upgrade grab a set of Magnum Blasters or Stebels. I swapped the puny horns on my FJR for the Blasters - its funny seeing driver/pedestrian reactions when Im on my bike.
Old Sep 6, 2007 | 12:04 AM
MadisonMini's Avatar
Rdenis,
Any idea how easy it would be to swap out our horns and replace them with the Magnum Blasters for the Outie?
Old Sep 6, 2007 | 08:02 AM
roach's Avatar
get yourself a set of Hella Supertone Horns and you will be happy friends of mine had some on his WRX and man those thing's are lound !
http://www.rallylights.com/hella/supertone_horn.asp
Old Sep 6, 2007 | 10:08 AM
klas's Avatar
Hm.... don't like the high pitched ones. I wish I could find the same tone as my previous car (TSX)
Old Sep 6, 2007 | 12:08 PM
Number6's Avatar
Exactly. The volume is fine, but more "HONK!" and less "BEEP!" if you please.
Old Sep 6, 2007 | 01:59 PM
bnilguy's Avatar
ORIGINAL: antlip
Yea the horn is pretty gay. They should of put an air horn in.
so that explains why I caught my horn plugged into another horn with the same polarity..
The stocker is a disc type of horn..the advantage is that it's small and the sound is 'aimed' straight out (you can see the horns from the outside so perhaps looks are a factor??)..they sound pretty lame and are usually found on motorcycles and japanese cars
I put an air horn on my bike and it sounds awesome..but they're much bigger (even the compact all in one units), so there could be some mounting issues and I don't trust the opening of the horn to be facing forward getting water/bugs/dirt in there
The signal type (kind of asprial look with a soundexit hole)of electric horn (what has been used in most domestics)..that's proably the sound you want..
Old Sep 6, 2007 | 02:01 PM
Train horn : )
Old Sep 6, 2007 | 04:15 PM
rdenis's Avatar
ORIGINAL: MadisonMini
Rdenis,
It should be a straight swap with the Blasters. I haven't looked to see how the stock horns are mounted/wired but I suspect they are flat cylinders with two wires so it should be easy to swap them.
Old Sep 10, 2007 | 05:18 AM
coolmael's Avatar
Just break the rules and fit airhorns - I did, and now the horn sounds acceptable!
Cost AUS$30, so a cheap fix.
I Drive Naked
Jun 4, 2007 07:51 AM
TheAdvocate
Apr 18, 2007 09:59 PM
risk636
Apr 16, 2007 09:47 PM
ba3kgt
Jan 11, 2007 10:13 PM
bluballz07
Oct 28, 2006 01:44 PM
