Outlander Sport LED Bulb Size List
Old Oct 3, 2012 | 01:26 AM
Burtonrider10022's Avatar
Default Outlander Sport LED Bulb Size List and Installation Pics
Originally Posted by Juz10 xD
Low beam HID-D2R HALOGEN-H11
High beam 9005
Fogs H11
Front markers 168
Turn signals (front and rear) 7440
Tail/brake lights are incorporated LED
License plate 168
Reverse light 921
Front sidemarker 168
Trunk 3022 (30mm festoon)
Map/dome lights 3175 (31mm festoon)
License plate bulbs and reverse bulbs you want a forward facing or 360 degree, the bulbs point downwards into the housings, onto the plate. If you go 360 degree, line the inside of the housing with either aluminum foil or white tape, not sure which one works best yet but i've tried foil which had a clean, even spread of light.
I'm personally more fan of the 5k white which will match the oem bmw/lexus/etc white. The 6k white seems to be a bit blue and doesn't output as bright.
Recommend using:
these for license plate
these for map lights
these for trunk
these for front/side markers
these for reverse
A member over on evoM posted this, and I just thought a few of you may like to upgrade your lights to some nicer LED's.
Last edited by Burtonrider10022; Oct 27, 2012 at 06:33 AM. Reason: Added pics and quick review.
Old Oct 27, 2012 | 06:36 AM
V-LEDs installed, will post a better review late tonight. First off, the interior map light bulbs are amazing, even though I accidentally ordered the wrong ones. I meant to order the "high output" ones, but somehow grabbed the regular ones instead. That actually makes these things MORE impressive in my book, I'd imagine the high output ones are just fantastic. The fit is a little bit tight, but wow are they brighter and better. Day it's noticeable, but at night it's amazing. I will get the H/O for my center roof light and report back on the difference
THESE 921 reverse bulbs suck IMO. I think my stockers were brighter. These will be removed and returned. Luckily they took about 45 seconds per bulb. Next I'm going to do the license plate bulbs, I just gotta figure out how to get the cover off them.
Old Nov 5, 2015 | 09:23 AM
ChelBell's Avatar
Question Vanity Light Replacement Bulbs
I just purchased a 2015 Mitsubishi Outlander Sport SE (my 3rd Mitsubishi vehicle) and I am attempting to "make it my own". I would like to replace the factory vanity lights with LEDs, but I can't seem to find the size that I need.
Has anyone had any luck with this? I want to replace them because I do not like how hot they burn.
Old Nov 6, 2015 | 06:24 PM
caskey_b's Avatar
DE3175 is the bulb... the 31 in the model means it's a 31mm festoon bulb..
so almost any 31mm festoon will work... I replaced mine with them as well.. not SUPER bright... but I didn't want them blinding
https://mitsubishiforum.com/forum/mi...hts-led-48928/
Old Nov 6, 2015 | 07:59 PM
ChelBell's Avatar
You replaced yours? I opened my vanity mirror light up, and the bulb does not look like a festoon bulb. It looks like a mini-wedge...like a T5 (74). The only bulb that are festoons (31mm) in my OS are the map lights.
Old Nov 6, 2015 | 08:46 PM
caskey_b's Avatar
Sorry... I assumed you meant the map lights... my bad
If I were you... see if your glovebox light will fit in the vanity light and work... glove box light is a 74
Old Nov 6, 2015 | 09:03 PM
ChelBell's Avatar
I don't have a glove box light. The only interior lights I have are: 2 map lights, 2 vanity lights, 1 cargo light and the LED strips for the panoramic moonroof.
f100cuscab
Feb 23, 2012 07:28 PM
OmahaOutlander
Jul 29, 2011 05:42 PM
phs17
Jun 14, 2011 08:06 PM
rtrackr99
Jun 7, 2009 04:36 PM
Prophet
Jul 25, 2004 06:10 AM
