Sportronic
RE: Sportronic
I rarely use it.. only time I can recall using it is when I take a long onramp curve slightly uphill.. For some reason when I give it a bit of gas it will upshift into 6th..so I just flick the paddle and return it to normal when I get up to speed
RE: Sportronic
I've used it on long downward grades to help keep the speed steady without riding the brakes.Usually when I shift over to sport mode I'm in 6th gear, and when I shift down to 5thit holds the speed steady without braking.
neo2040
07-06-2007 11:55 AM
eclipse6racer
01-02-2007 08:11 PM
1st, 2nd, bad, eclipse, faq, gas, how, mitsubishi, mode, outlander, save, shift, sportronic, sportronics, time
