Spring repair time, rear wheel bearing crack on 2016 Outlander AWD
Old Mar 16, 2025 | 11:56 AM
Truwarrior22's Avatar
Default Spring repair time, rear wheel bearing crack on 2016 Outlander AWD
So my dash lights up intermittently (4 or 5 warnings). Took the car to have a screw removed from the tire and they found that the wheel bearing has a crack. Could be messing with the wheel speed sensor. Purchased a rear wheel bearing (OEM part) and will be replacing it and the rear rotors this spring. Anyone else have a crack or other failure before? It appears it common for the wheel speed clip to corrode causing issues…just odd it cracked… Any bear part recommendations? These OEM parts are pricey.
Also looks like a need a new front passenger lower control arm, ball joint is a little loose… my wife did hit a curb on that side a few years ago…
Old Mar 23, 2025 | 07:00 AM
All fixed, appear just the speed sensor ring cracked.
Not sure why this happened…?
1949carguy
Aug 3, 2023 05:39 PM
raptornexus
Feb 2, 2017 04:15 PM
sk8dudety
Jun 9, 2007 10:46 PM
nitinbud
Apr 12, 2007 07:22 PM
97MitsuMonSport
Apr 5, 2005 10:04 AM
