Turn DRL on/off with switch?
Old Apr 15, 2012 | 07:54 PM
  #21
Phatty McPatty's Avatar
I was responding specifically to jolyrgr:
Originally Posted by jolyrgr
My job requires that I be able to watch my employees and test their work habits. Many times, I need to be able to drive in to a remote area undetected, and that means turning lights off so as not to be seen. While I can use the parking brake method after I get to a suitable spot, I cannot always get into position first. Then there is the issue of being spotted as I leave...
Old Apr 17, 2012 | 08:55 PM
  #22
jolyrgr's Avatar
Removing the bulbs was not an option as I do not have HID lights. The DRL function is just a reduced voltage sent to the driving lights. My solution was to run a relay to each side with a spare set of harnesess, and trigger off of the marker lamps. The only "damage" to the factory harness is the tap for power placed on the marker lamp wire. If I want the DRL working, I just turn to the first position on the headlamp switch. Otherwise, they remain off when the switch is off, just like any pre-DRL vehicle.
Best of both worlds as best as I could make it. 30min of work and easily reset to factory condition.
Old Apr 18, 2012 | 12:57 AM
  #23
ivanz's Avatar
Why not just buy the Lexia tool? It'll add features which would cost you much more in parts alone. Turn DRL off in the ECU and problem solved...
jimlever
Jun 22, 2014 09:53 PM
2000MontyLtd
May 7, 2011 10:26 PM
Chris_FL
Mar 29, 2011 06:04 PM
Dumbo45
Jan 23, 2009 09:29 AM
dornstar
May 22, 2006 04:58 PM
