USB cable
Old Jul 29, 2016 | 09:16 AM
albief's Avatar
Default USB cable
Does anyone know why you have to use a USB cable and not connect the USB stick directly into the outlet, I just purchased a Samsung USB 3.0 stick which is supposedly fast, but what speed does the USB cable run at.
Is it really necessary to use a cable, I know the manual advises it, but WHY??
Old Jul 29, 2016 | 09:58 AM
guxu's Avatar
It is just for "heavy" USB devices to protect the USB port. Your USB stick should be fine without the cable. That being said, I do not think the USB port is even USB 3.0. We do not need USB 3.0 to play music files.
Old Jul 29, 2016 | 11:59 AM
theSaint024's Avatar
The usb cable is probably referring to use with a usb harddrive, not flashdrive. I have used both and work fine. My flashdrive is plugged directly in.
guxu: FYI, usb 3.0 is not necessary to play files, but it makes transferring files from your computer much faster. usb 2.0 works too. If you don't have too much music, it probably doesn't matter, but then again, usb 3.0 drives don't cost much more these days.
VPower
Feb 17, 2015 06:45 AM
MassMitsu
Mar 8, 2013 03:11 PM
Blu Sprint
Jun 16, 2011 03:04 AM
dbblackdiamond
Sep 28, 2010 08:03 AM
p6793026
Sep 23, 2008 02:38 AM
