wheel question, i need help fast
Old Jun 5, 2013 | 09:38 AM
JRK5892's Avatar
Default wheel question, i need help fast
will a 18x8.5 with a +35 offset work on my 2010 outlander? I have a smoking deal on as set and i want to be sure that they will work before i pick them up!! thanks
Old Jun 5, 2013 | 12:21 PM
Claude_A's Avatar
There is more than size and offset.
On stock 18" wheels for the Outlander
the bolt pattern (PCD) is 114.3,
the centre bore is 67.1mm,
the rim width is 7",
and the offset is 38mm.
I am not sure that 8.5 " is not going to rub.
Try playing with the live application at tirerack.com or 1010tires.com
Old Jun 7, 2013 | 03:25 PM
ckmecha's Avatar
I have 18x8 wheels on mine, no problem there. Mine are 45mm offset so the 35mm 8.5" wide wheels would have about 1/8" MORE clearance from the fender well.
ProjectDrknss
Aug 9, 2007 01:39 AM
BigDASH
Aug 8, 2006 09:44 PM
green_eclipse94
Jan 15, 2006 08:19 PM
sreps
Jan 21, 2005 08:55 PM
unplugged_nate
Jul 2, 2004 11:32 PM
