When ignition is on a strange buzzing is heard. Is this noise normal?
Old Aug 11, 2016 | 11:05 PM
Sic_Lucky's Avatar
Default When ignition is on a strange buzzing is heard. Is this noise normal?
I noticed tonight as I was installing a backup cam that when the ignition is on there is a weird buzzing sound coming from under the hood. I popped the hood and the noise sounded like it was coming from the top of the engine around the valve covers area.
I don't recall noticing this before and I know that relays and stuff come on when you turn the ignition on but from what I recall they soon go off. This noise stayed on.
Anyone has any ideas? Is this normal? Does your Outie do this?
Old Aug 14, 2016 | 03:06 PM
Sic_Lucky's Avatar
I did some investigation today on that buzzing noise and it's coming from the throttle position sensor. When I disconnect the plug to it the sound is gone.
I've done a throttle body replacement on a 94 Prelude before, anyone know how difficult it is to replace the throttle body on the Outie? Or will it be easier to just replace the sensor?
Old Aug 14, 2016 | 04:26 PM
gggplaya's Avatar
I took my throttle body off to clean it, it's not hard. Just keep removing the air intake parts until you get to it. There are a bunch of clips and stuff which hold wires in place. Then there's a small bracket which holds the throttle body up.
Old Aug 14, 2016 | 07:07 PM
Sic_Lucky's Avatar
Can anyone do me a favor and turn your ignition on, pop your hood and listen for a buzzing from the tps area. I just want to know if this is normal in outlanders, I don't have the noise coming from my 04 lancer (but it's not a drive by wire set up). I want to be sure before throwing money at it. Thanks
Old Aug 28, 2016 | 11:35 AM
Sic_Lucky's Avatar
Bump!!
Old Apr 3, 2017 | 05:53 PM
Sic_Lucky's Avatar
Can anyone do me a favor and check if their tps buzzes/humms when ignition is on.
Corbul
Jan 31, 2023 09:25 AM
dashnine
Mar 19, 2019 02:44 PM
ShortyRider
Dec 13, 2012 11:52 PM
dorian7
Aug 8, 2007 04:53 AM
aswahdan
Nov 12, 2004 10:25 AM
