tranny>????clutch??
Old Dec 1, 2006 | 02:49 PM
  #21
Default RE: tranny>????clutch??
450 to the crank i guess could be possible so i guess your right there. I wasnt sure. And also the FPR is mainly for idle and very low psi fuel pressure correct?
Old Dec 1, 2006 | 07:31 PM
  #22
silvercoupe97's Avatar
ORIGINAL: TheEngineer
The stock FPR is a 1:1 FPR too so it's on as soon as the car is started up and ran through the rev range just like an AFPR. The reason it get overrun is because of that tiny return tube, well the entire fpr is tiny. It has a tiny diaphram that is open and closed by the hg tube that is housed within the tiny casing. It's very easy for it to get overrun with a larger flowing pump.
Old Dec 11, 2006 | 01:02 AM
  #23
spyder4g63t's Avatar
660hp injectors,255 fuel pump, regulator, and filter then im good
Old Dec 11, 2006 | 01:06 AM
  #24
ORIGINAL: spyder4g63t
660CC injectors,255 fuel pump, regulator, and filter then im good
fixed
Old Dec 11, 2006 | 01:09 AM
  #25
thanks alot man
Drummerkid505
Feb 23, 2008 01:17 AM
Drummerkid505
Feb 6, 2008 06:41 PM
bud660r
Dec 16, 2006 04:34 AM
novetek
Mar 30, 2006 06:34 PM
martpro21
Jan 23, 2006 01:12 AM
