please help (newbie)
Old Feb 27, 2008 | 03:26 PM
crazyeman1's Avatar
Default please help (newbie)
hey. first off, im new. i have a 1990 eclise gs turbo. the problem is, it wont hold a steady idle. when you rev it up to 2000 rpms or more and try to hold it, it revs up then cuts out. it wont stay there. i have replaced the plugs, wires, fuel filter, ignition control mod, coil pak, air flow meter, and cleaned the injectors. nothing works. any suggestions?
Old Feb 27, 2008 | 04:46 PM
Rob's Avatar
Rob
Default RE: please help (newbie)
Have you checked all vacuum hoses for leaks, cracks, or breaks?
Old Feb 27, 2008 | 07:13 PM
usually it will have to do with the ISC motor but i would start with the vacuum lines. Also check out www.vfaq.com for a write-up on the fluctuating idle faq
enzo_hashmat2006
Oct 10, 2017 05:46 PM
Ninjobitch
Aug 21, 2013 12:35 AM
ukiltmybrutha
Jun 19, 2011 03:06 PM
tiller801
1st Generation
Feb 14, 2008 10:25 PM
roberttkim
Dec 25, 2004 12:53 AM
