timeing belt went
Old Nov 27, 2006 | 08:53 PM
  #21
Default RE: timeing belt went
ORIGINAL: Sanguinius
ORIGINAL: red93gs
i know it involves alot of building up i was planin on pickin up a turboed block i dont know yet
There is NO difference from a turbo to an N/A block. If you're building up for a turbo the block will be the same either way. The difference will be the internals, the ECU, and the supporting systems. And if I'm not mistaken, the internals (Pistons/rods, cams, crank, and I think even the valves) were the EXACT SAME for both engines (Actually I think the valves might have been different butt he rest the same). So save the $ and get your block pulled and honed and just rebuild it.
the pistons have got to be different the rods maybe not but NA needs higher compression than FI I would guess the NA pistons are far from the same
Old Nov 27, 2006 | 09:11 PM
  #22
^^^ sounds right to me.
Old Nov 28, 2006 | 12:00 AM
  #23
ORIGINAL: 93eclipsegsx
250+ shipping. just needs to be cleaned. it came off a running car. price is negotiable.
also i have the 6 bolt block to go along with this head .
200+shipping (but i would perfer pick-up)
Old Nov 28, 2006 | 12:04 AM
  #24
and i agree with mike about the pistons. He is correct the compression of the pistons is WAY different. I think the 1g;s are around 7.8:1 while the NT is around 9.0:1
and also woody is right that the 1g's have the oil squirters under the pistons
Old Nov 28, 2006 | 12:24 AM
  #25
93eclipsegsx's Avatar
ORIGINAL: TheEngineer
thanks john for clarifying my post, wasnt for 100% sure.
Old Nov 28, 2006 | 03:04 PM
  #26
Sanguinius's Avatar
Interesting then I was misinformed about all that oh so long ago. If someone has a pic of what N/A pistons look like I have a set of turbo pistons here. Could compare. BTW they're for sale LOL (Got them a while ago never actually did anything with 'em and I have a G54B now not a 4G63).
Old Nov 28, 2006 | 04:50 PM
  #27
It is pretty easy to think that the pistons would be different between NA and FI since FI always uses low compression and NA uses higher compression
trainfun
Oct 10, 2019 04:58 PM
Gary Alford
Apr 28, 2015 11:11 AM
JR140
Jan 8, 2006 01:02 AM
spydernoob
May 26, 2005 10:54 PM
larre
Feb 12, 2004 02:15 AM
