16g install troubles
Old Jun 23, 2008 | 10:07 AM
19gst98's Avatar
Default 16g install troubles
ok so i gave my mechanic a evo3 16g and a 2g install kit. he said he needs instructions because he cant figure it out because nothing fits. i dont know what to tell him because from what ive read there shouldnt be any problems. its starting to **** me off cause i want my car back. any good links for instuctions or any good advice? thanks
Old Jun 23, 2008 | 11:06 AM
jerusry's Avatar
Default RE: 16g install troubles
if you gave him the install kit its pretty self explanatory. you gotta be a dumba$$ to not figure it out. as long as you got the whole kit. as for anything that may need to be modified at all... the lower intercooler pipe that normally comes off poinintg to the passenger side now need to connect to the jpipe wich faces down. he may have to cut it a wee bit shorter to fit. other then that.. it took me i think an hour to install my 16g. and install kit when i installed it. pretty simple stuff. you might be better off doing it yourself and i could walk you thru it. save your *** money. he clearly doesnt know what hes doing if he cant figure it out. and its not worth your money. i would say you would know what to do just as good, and with our help better then he could. especially if he cannot figure it out himself.
Old Jun 23, 2008 | 12:21 PM
19gst98's Avatar
yeah i got a 2g install kit from dsmparts and the turbo from slowboy racing, he just has the instructions for stock applications. but should the 16g bolt onto the stock 2g exhaust manifold. i also read somewhere about switching water lines from front to back. i just dont think i have the time and resources to do it myself.
Old Jun 23, 2008 | 02:47 PM
jerusry's Avatar
it bolts up just like stock besides the jpipe and piping i mentioned. other then that everything you have should be enough. yes, it bolts up to the stock exhaust manifold. the one thing i can think of that may be different is that i believe 16g's dont have the vaccum nipple on there that goes to the actuator.. you can run that from another vaccum point. it is just slightly different than the stock. you can tap into the line that comes off the blowoff valve to control for the actuator. there are other ways you can do it, but for now that is the easiest.
Old Jun 23, 2008 | 03:20 PM
Yeah if he cant figure it out, then you need to take the car back and DIY.
Its just removal of a few bolts... you should be able to do it easily.
Old Jun 23, 2008 | 03:38 PM
jerusry's Avatar
yeah n like i said.. my 16g if i remember correctly only took about an hour to install...maybe 2. but it is very simple.
Old Jun 23, 2008 | 07:04 PM
dsm1990gsx's Avatar
You should have taken it to a dsm specialty shop. I wouldn't trust the average mechanic to do it.
get435
Mar 17, 2011 04:33 PM
BrunoBoy650
Apr 10, 2007 03:27 PM
Tiberius
Sep 29, 2005 10:51 PM
o0olifeguardo0o
Apr 18, 2005 09:44 PM
DR_NO
Feb 14, 2005 11:57 PM
