6 bolt build
all forged internals. A ported head would be good. Some decent valves etc. Cams, HKS 272's would probably work best(with a good engine and head you can rev higher). Obviously a BIG FMIC. walbro 255lph fuel pump, afpr, some big injectors, wide band o2 sensor, and a DSM link should cover it. Of course you will want a 1g throttle body and intake manifold. Would you like links to any of these parts?
thanks paint. oh and ive spent 6k on the motor alone and i have alot more to go, like 5k more. oh well its my PROJECT . i plan on using the 37r, i have made my decision. i hope the 38mm wastegate will hold at 35psi.
holy crap 93gsx..... 6k and still have 5k more to go??? mabey i'm just misunderstanding the websites i've been looking at. for instance Buschar racing makes a stage 3 head and block both suporting up to 900whp.... can you not just buy both the head and block, put them together and BAM you have an engine that will suport 900whp?
well with buschur, you cant just buy a block and a head and expect it to run. You need cams, intake mani, FUEL, turbo. Stuff like that.
I spent $8k on my motor and clutch and it will not support 900whp. Plus i still have to pay for fuel, intercooler, and dsmlink. And i will be upgrading turbos 2 so ive got quite alot of $$ to go. A bad *** motor from ffwd connections will run you about $11k and that includes an intake mani and cams.
well here is the list of stuff i have and stuff i need.
[align=center]HAVE
[align=left]1. buschur stage 3 long block
2. hks 272/272 cams
3. metal hg
4. arp head studs
5. polished tial 38mm wastegate
6. balance shaft eliminator kit
7. greddy timing belt
8. aeromitive afpr
9. walboro 255
[align=center]NEED
[align=left]1. aem ems
2. garrett 37r
3. ams dsm vrs
4. shearer manifold
5. tial bov
6. big injectors
7. lifters and rockers
and i might be missing some stuff.
[/align][/align][/align][/align]
[align=center]HAVE
2. hks 272/272 cams
3. metal hg
4. arp head studs
8. aeromitive afpr
9. walboro 255
[align=center]NEED
2. garrett 37r
3. ams dsm vrs
4. shearer manifold
5. tial bov
6. big injectors
BrunoBoy650
Dec 4, 2008 08:50 AM
