new car batter, still wont start
Old Oct 25, 2006 | 10:33 PM
flipp117's Avatar
Default new car batter, still wont start
Hello everyone,
I've spent the last few hours going through forums but I have not found anyone with a similar problem as me. I have a 96 gs automatic and the car will not start. It appeared that the battery was dead i.e. lights won't turn on, horn does not work, alarm is very low. I took the battery to kragen they tested it and said the battery is fine. I used a different battery and the car started up fine so I went back to kragen and bought a brand new battery. I put the brand new battery and I still have the same problem. It looks as though once again there is no power in the battery. Any ideas will help.
Thanks in advance.
Old Oct 25, 2006 | 10:34 PM
Default RE: new car batter, still wont start
Alternator.
I would check ALL the fuses too. (box under the hood and in the car)
Old Oct 25, 2006 | 10:43 PM
flipp117's Avatar
Thanks, I'll check those out when I get home. Will the car still start even if the alternator is not working because the battery should have enough charge to start it?
Old Oct 25, 2006 | 10:56 PM
paintballproam's Avatar
well if the alternator isnt charging the battery then it isnt going to have any charge to hold
Old Oct 25, 2006 | 10:57 PM
estraw's Avatar
ya the car should still start but it would die after a few minutes w/o an alternator
Old Oct 26, 2006 | 01:56 AM
flipp117's Avatar
i just got home and tried other batteries, none of them work so its obviously not the battery. All fuses are fine, I checked the wires from the battery leading to the ground and everywhere else, and they all look to be ok. I'll keep you guys posted on what the prob is. Thanks!!!
Old Oct 26, 2006 | 09:36 AM
is the car trying to turn over?
Old Oct 26, 2006 | 02:47 PM
flipp117's Avatar
the car wont turn over because it appears as though there's not enough power coming from 2 batteries that I know have power. Someone told me it sounds as if it has a bad ground so ill check those out.
Old Oct 26, 2006 | 02:48 PM
Do you hear a click when you turn the key?
Old Oct 26, 2006 | 03:07 PM
flipp117's Avatar
hey guys, it was a bad ground. I was told to connect the neg battery to a different ground position using jumper cables, and it worked like a charm. Thanks for all the help guys!!!
montplusrs
Jan 31, 2014 12:45 PM
frank101
Jan 23, 2012 06:07 PM
95eclipse420a
Oct 19, 2007 08:00 PM
Shownolove
Apr 26, 2006 10:54 PM
red92eclipse
Oct 22, 2004 12:38 PM
