Shift Solenoid
#22
RE: Shift Solenoid
OK, here is the latest. I've reassembled everything and I still have the same problem. I did test the solenoids two ways. I gave them 12v power and all clicked. I tested resistance and they all gave proper OHMs.
I still have a problem with not being able to shift into reverse (it doesn't evenact likes it wants to try)or have the trans change gears when in drive. I can let up the gas and then hit it again to get second gear at high rpms... then it might slip into neutral until I slow enough and it will return to 1st or second.
This all worked perfectly fine just a few days ago.. this problem happened all at once.
The only thing I can think of at this point is a bad TCM.
I would love anybody's input on this.
Eclipse440
07-14-2015 11:08 PM
2000Monty181
11-12-2013 10:49 PM
Hemihunter
08-10-2011 05:52 PM
