TDC on 4g63 head
Old Apr 3, 2007 | 12:17 PM
clips69's Avatar
Default TDC on 4g63 head
ive been fustrated, cut ,stitch up tryn to get this damn head aligned....when putting the timming belt back on had to manualy align everything crank, balance saft, and last the head...as tryn to maualy align it on its mark with my hands it suddenly jumped twist with my hand slicing my fingers on the metalcam gear cover...so now each cam gear isnt in itsplace....(there are two marks on the exhasuxt and one on the intake)when aligned it looks like -0- -0 is the numbers or letters on the cams bothon the readable side?
Old Apr 3, 2007 | 12:23 PM
Dusty Eclipse's Avatar
Default RE: TDC on 4g63 head
I dont understand the question.. kind of just a jumble of words... But, you know you can eliminate that balance shaft and save weight, gain power and never have to deal with it again?
Old Apr 3, 2007 | 12:40 PM
clips69's Avatar
oh sorry kinda hard to explain if you cams are align with the tdc marks would the letters and and nubers marked on it both be horizontal
Old Apr 3, 2007 | 12:46 PM
im not sure exactly what the letters would have to do with it. The two things that should be aligned for the cams are the timing marks on the sprockets facing each other at 3 o clock on the exhaust and 9 o clock on the intake. You also want the dowel pins to be at 12 o clock. Doing that should give you thecorrect timing.
clips69
Jun 4, 2007 02:31 PM
frakinstine
Nov 4, 2005 02:02 AM
frakinstine
Nov 1, 2005 03:25 PM
frakinstine
Oct 29, 2005 07:16 PM
thunderman
Nov 16, 2004 01:43 PM
