Starter engages when clutch pedel is depressed?
Old Nov 10, 2006 | 12:04 AM
MITSGSX16B's Avatar
Default Starter engages when clutch pedel is depressed?
I just purchased a 97 GSX and just today this issue cropped up.. I'm not sure what could be causeing this behavior. I can reach under the dash and just push the pin/button, which is usually depressed by the clutch pedel, under the dash and the starter engages, even without the key in the ingition. Any suggestions? I've heard of relays going bad, if so anyone know where this relay is? Thanks in advance for all your help.
Old Nov 10, 2006 | 01:29 PM
VR4GARY's Avatar
Default RE: Starter engages when clutch pedel is depressed?
It could be a stuck relay. The relay should be in one of the boxes under the hood. The cover will tell you which one is the starter. You might also check for a loose wire on your ignition switch. You might have to remove the steering housing to check.
kostovski.dragan
Jul 30, 2014 04:55 AM
ImaIVIonsta
Feb 25, 2012 10:58 PM
RonP
4th Generation
Apr 20, 2008 08:58 AM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
