03 no start
Old Aug 25, 2015 | 12:08 AM
  #51
The wire in the last photo (running right between serpentine belt and the engine block) is the crank position sensor wire. It is supposed to be going down that way. There normally couple holders to keep it tucked in right up to the engine, so that it would not get mangled by the belt.
The other connector should go to Evap purge solenoid. Here is a photo what mine looks like. I wonder if PO removed it from your truck.
Old Aug 25, 2015 | 10:14 PM
  #52
jp1985's Avatar
Originally Posted by Guyfromhe
That looks like an important wire and it also looks like someone was messing with it after the factory... Do you have the other end for that wire?
I haven't been able to track it down. I will have to try and get to it when i have a chance to work on my monetero time sucks right now .
Old Oct 9, 2015 | 07:10 PM
  #53
jp1985's Avatar
Angry Died today
I was trying to limpet home a few miles back to my house. I started making this sparking noise followed by me losing power followed by me breaking down I was able to get it to pull it into a safe spot off the side of the freeway.
when I pulled over and smoke started coming out from the hood open the hood it look like it was from the bottom lower side of the engine sort of over by where the oil Cap is.
I'm hoping that this didn't ruin the entire engine in it it's just that valve gasket fixed or something easy like this ever happened to you guys.
Sparking noises followed by lack of power followed by dying and smoke coming out of the engine by the engine oil.
I'm really afraid that it might've blown head gasket but I don't want to think that.
I'm having it towed home now.
any advice guys thank you. Will have to look at it more at home I am afraid to start it.
Old Oct 9, 2015 | 07:36 PM
  #54
jp1985's Avatar
Tow truck driver said sounds like a timing belt! Crap I hope not it's an interference engine.
Old Oct 10, 2015 | 09:45 AM
  #55
Guyfromhe's Avatar
The internet seems to be at a consensus that the 3.0 L 24v engine is a interference engine...
Old Oct 10, 2015 | 11:37 AM
  #56
jp1985's Avatar
Yeah from what i researched it all says the 3.0-3.8 are all dohc interference engines .
Guess i will have to open it up and check it out today.
Not looking forward to this.
Old Oct 10, 2015 | 04:27 PM
  #57
The Viper's Avatar
you need to seriously come up with a way to research more accurately
the 3.0l mitsubishi montero is a non-interference engine
the 3.5l mitsubishi monteros came in both SOHC and DOHC, the DOHC is rare.
the 3.8l found in 2003-2006 mitsubishi monteros are SOHC
Old Oct 10, 2015 | 04:29 PM
  #58
jp1985's Avatar
so the 3.5 is not an interference engine?
Old Oct 10, 2015 | 04:37 PM
  #59
The Viper's Avatar
the 3.5 SOHC aand DOHC are interference engines
the 3.8 SOHC is interference engines
the 3.0 is tricky, some say yes it is interference, some say no...so i guess i would consider it interference.
my details on the 3.5L and 3.8 are 100% accurate
Old Oct 10, 2015 | 11:09 PM
  #60
On what basis did the truck driver made the "diagnosis" of the issue at hand being a timing belt? Don't panic too soon.
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
