1995 montero sr starter spins but engine wont crank
Old Apr 28, 2013 | 09:48 PM
Cid's Avatar
Cid
Default 1995 montero sr starter spins but engine wont crank
hi.I own a montero sr 1995 and i really enjoy it.it have develop a starting problem the starter will spin but it wont crank up the engine.i bought two new starters and the second will crank the engine sometimes,and when it does it will start roughly and with a loud thump.once is running it runs great as usual.any ideas?
Old Apr 28, 2013 | 10:37 PM
Your flywheel is probably missing teeth. Take off the starter and rotate the flywheel with a screwdriver. You should see the damage.
Old Apr 30, 2013 | 06:44 AM
Jeff Collision's Avatar
The problem is you may have bad starter motor. To check this, disconnect the negative battery cable for safety. Remove the starter access cover. Unplug the wiring modules from the starter. Remove the bolts mounting the starter. Use a penetrating solvent to loosen the bolts if they are too tight. Do not discard the old starter. Place the new starter in the same position as the other. Use the torque wrench to tighten the bolts to between 20 and 25 foot-lbs. Reconnect the wiring module. Crank the vehicle, to make sure the starter is working correctly, before re-assembling the other components. Replace the starter cover and the engine brush guard. Reconnect the negative battery terminal. You can get starter from buyautoparts at best price for your 1995 Montero.
Old May 1, 2013 | 04:34 PM
Cid's Avatar
Cid
Thank you for your responses.I did put a new starter and it make no difference i check my flywheel thru the starter hole and it looks like is fine, teeth are a little bit rounded but not to bad.It actually sounds like it engages but it have trouble cranking. i did check the voltage on the starter end and is over 12.8 and the battery is new.
Old May 1, 2013 | 05:18 PM
You rotated the starter all the way around?
04 Endeavor
Nov 27, 2011 12:32 PM
Tmandorfer
Jun 23, 2011 09:32 PM
jsneed24
Apr 14, 2008 09:39 PM
cod1ak
Mar 28, 2008 08:55 AM
blumaverick
Feb 15, 2008 01:09 PM
