Changed the water pump, timing belt now it won't start
Old Sep 10, 2007 | 11:40 AM
jason clipse's Avatar
Default RE: Changed the water pump, timing belt now it won't start
u could also have the timing marks right but 180 degrees off make sure those marks are on when number one cylinder is at TDC
Old Sep 10, 2007 | 05:50 PM
matthew_m75's Avatar
Good idea. while were on that subject i've been assuming this is overhead cam like 97 montero sport. If it is then the crank and both cams should have permanentley mounted timing marks on the block. Either waygoodidea to double check your at Top Dead Center on your timing mark
Old Sep 11, 2007 | 08:09 AM
raycam2kx's Avatar
Thanks guys, I am going back in on Thursday, will post when I check out all suggestions. I will still check for any new posts until then though.(oh-yeah overhead cams).
Old Sep 21, 2007 | 03:34 PM
raycam2kx's Avatar
News is good! I had the pins (spenal?) in the gear (behind the crankshaft pulley) mis-aligned. The truck starts right up now! Thanks for all info guys.
Old Oct 6, 2007 | 08:31 PM
raycam2kx's Avatar
Update: FYI Now I find out it was the sensor that is why I couldn't set the timing.
adamsstreetauto
Feb 23, 2018 05:43 PM
raycam2kx
Feb 21, 2008 11:08 PM
Wi_Fibre
Jan 16, 2008 12:17 PM
raycam2kx
Aug 16, 2007 08:33 PM
dsfii
May 10, 2005 03:08 PM
