Lift suspension and tires question
Old Feb 5, 2006 | 01:45 AM
mitsuchallenger's Avatar
Default Lift suspension and tires question
Newbie here. Searched and I have an idea to the answer but I will ask anyway for clarity.
Have a 2003 Limited AWD and I will be replacing the tires soon. It came with stock 255/70/16s but want to upgrade to a larger size - 265/75/16.
Will I have clearance problems with a stock height suspension?
Also thinking about lifting it next year. Any suggestions on lift kits preferably from OME or the likes. Or any lift suggestions. I live in LA CA and Ive searched the internet and cant really find any shops that deal with Mitsu 4wd service parts and accessories.
Thanks.
Old Feb 5, 2006 | 09:36 AM
montero1's Avatar
Default RE: Lift suspension and tires question
My 03 limited- email me if you have any questions-
http://www.cardomain.com/memberpage/712331
prtdvl@yahoo.com
Old Feb 5, 2006 | 01:17 PM
jc_ride's Avatar
There should not be any clearance problems. I have 2000 XLS and I put the same size tires that you mentioned on mine and they worked fine. For a lift kit do a search for "Old Man Emu" as they are the only company that makes suspensions for Mitsubishi SUV's.
Old Feb 5, 2006 | 01:54 PM
Thanks for the quick replies jc and montero1.
Its good to read that the 265/75/16s will fit the stock suspension with no problems.
That size offers more price choices (lower ) in the AT and MTs.
I read up on the OME jc and they have a pdf on what they have for the MS. Its almost like a restaurant menu.
Just have to read some more of how to "crank up" the torsion bar for the front lift. And OME will take care of the rear. Shocks too.
I will probably have some detail questions on "cranking up the T-bars" later. Need to read first.
I forgot to add the "Sport" in my post - just to clear things up.
Thanks again from a fellow Mitsu owner. See you the trails.
Old Feb 6, 2006 | 06:30 PM
off roader's Avatar
ORIGINAL: jc_ride
JC, I'd like to clarify this a bit in case a Montero owner reads this thread... What you've noted is probably correct for the Challenger/Montero Sport but it's incorrect for full size Montero.
There are several who make suspension upgrades for Montero's.
Sway Away: USA / www.swayaway.com makes a heavier duty torsion bar for some Montero models.
Iron Man Suspension: Australia / www.ironmansuspension.com makes a heavier duty torsion bar
Valley Spring (Dixon California) makes heavier duty coil springs.
Motorcare: Australia / www.Motorcare.com.au also sells a suspension lift kit for gen III montero's.
Alternatively for a Montero Sport / Challenger Sport instead of replacing leaf springs you can probably do a spring over axle suspension mod and torque the front torsion bars and fit up to 32's if not 33's underneath.
HTH.
inandout
Mar 18, 2021 03:48 PM
westy
Nov 29, 2009 08:22 PM
CJ3B
Nov 8, 2008 07:05 AM
mtalma
Nov 12, 2006 08:09 PM
gs_dirtdog
Nov 10, 2006 07:35 AM
