08 Outlander - MMCS Replacement questions
Old Mar 22, 2015 | 07:18 PM
jdubnz's Avatar
Default 08 Outlander - MMCS Replacement questions
Hey All,
Im looking at ripping out the MMCS unit in my 08 Outlander 30G, Can someone tell me if the built-in camera can be used on a different head unit? and will the AMP currently in the car be able to work with a different head unit or will i need to bypass this and put a different amp in?
Old Mar 22, 2015 | 07:29 PM
firebuck's Avatar
I do not know for sure but usually the cameras can be adapted with some splicing to work with many systems. Most people change the amp or just leave it there not hooked up as the factory one usually uses odd wiring and inputs making an aftermarket amp a better choice.
Old Mar 23, 2015 | 12:32 PM
Vadimus's Avatar
Stock camera is powered by special 6V output from MMCS, you will need to find a replacement power source if MMCS is removed.
mihoo
Jul 19, 2020 11:23 AM
M.a.S.e
Aug 18, 2013 03:59 AM
Buster005
Apr 3, 2013 08:43 AM
Blu Sprint
Jun 16, 2011 03:04 AM
lordtygr
Sep 1, 2009 09:43 PM
