2003 Outlander - feels weird on ice
Old Mar 25, 2014 | 02:00 PM
Paulrus's Avatar
Thanks Claude!
I lived in New Hampshire for 8 years, so I probably experienced similar driving situations to you.
Does the Outlander have any sort of traction control, then? My gut feeling when driving was, there was no traction control at all & what I was feeling was the individual tires slipping & regaining traction which pulled the car in a "squirrely" fashion.
The tires are probably an issue as well. They're a cheap no-name brand that I'm assuming the used-car dealer put on so he could list "new tires" as a feature.
Thanks for the reply! I appreciate it.
-Paul
Old Mar 25, 2014 | 02:04 PM
jkeaton's Avatar
If your vehicle is equipped with traction control, it will have a switch or button to turn it on or off. Your owners manual is a great resource.
Old Mar 25, 2014 | 02:17 PM
Paulrus's Avatar
jkeaton - thanks. I really appreciate your friendly, helpful response.
Since I bought the car used, just a couple of months ago, there was no owners manual. And, although generally cars with traction control will have methods to enable or disable the function, it is not unheard of for a car to have a form of traction control that is simply always on.
Because I'm a new owner of the Outlander, I was not sure if it might have a limited slip or some other form of traction control that could be the issue. I came here looking to get some input and advice from other owners who perhaps have gone through something similar.
Your friendly responses have made me feel most welcome here. I sincerely appreciate your time and hope you have a great day.
-Paul
Old Mar 25, 2014 | 02:20 PM
Claude_A's Avatar
Your car is 2003 so I suspect it has only low speed traction control using the brakes to slow the runaway wheel.
Check your manual for description of whatever traction control there is but I think there is a speed limit for a 2003 car and my feeling is probably 30 mph max otherwise you will burn the brake pads.
If the tires are that poor then plan in getting better ones or getting winter tires for that time of the year.
Your life hang on 4 patches of rubber of about 10 square inches each.
Old Mar 25, 2014 | 02:59 PM
jkeaton's Avatar
-Paul
No problem! Glad to assist.
Old Mar 26, 2014 | 01:11 PM
YahFargo's Avatar
Originally Posted by Claude_A
Tires....plus remember ice is not dry but covered with patches of water or snow.
Tires are loosing and regaining traction at random hence the movement you are feeling.
AWC, AWD, 4x4 are no better on ice than 2wd in fact probably worst as they try to compensate by switching torque around at the same time as the tires are fighting for grip.
All the 4 wheels drives are better at is the Go not better at bracking or staying on track.
4 seasons tires loose traction at around + 7C and lower if you drive on ice often get ice rated winter tires otherwise you will be better driving a FWD with open dif that will not fight the tires.
I have 40 years of winter driving and learned to drive in the Canadian Artic ad drove everything from VW bug to fuel tanker and felt that unsetling giggle many time in the seat of the pants while driving on slick road.
Remember your only contact with the road are the tires.
+1. Tires, tires, tires
Old Mar 13, 2025 | 08:31 PM
Myride's Avatar
Thanks, but does anyone have any comments or thoughts on this subject?
I honestly have no idea why you've decided to comment the way you have Akzle. Is my question that unworthy of a reply?
Really, I am 100% new to the Outlander and I don't know if this is a known issue, if this is normal behavior or if I have a problem I need to check out.
I've already dealt with a frozen caliper which caused a rotor to warp. But I can't find any information anywhere on this odd behavior on ice that I've experienced.
-Paul
I'm having the exact same issues with my 2023 Outlander SE bought it to the dealership to have them look at it two weeks ago they replaced the shocks today they did it in alignment and none of that helped it's all over the road when I hit a bump especially it
Slides its own way like fishtailing it's pretty scary when it happens at low speeds I can't imagine at high speeds if I hit a bump book what could happen and then on the ice as well it felt like the car was going to do a 180 I had no control over the car on ice at all please help I'm new to the Mitsubishi ownership As well as if something that I need to be concerned about I'm almost ready to seek legal counsel on the matter I paid $34,000 for my car and for it to handle this way kind of makes me sick to my stomach.
Old Mar 13, 2025 | 08:36 PM
Myride's Avatar
Default 2023 Outlander SE goes into a slide when going over a bump
-Paul
aganthorp
Dec 23, 2009 06:25 PM
adgjqetuo
Feb 18, 2009 08:58 AM
tjbiker031
Apr 3, 2008 11:16 PM
paintballproam
May 30, 2007 02:26 AM
BrunoBoy650
1st Generation
13
Jul 24, 2006 06:55 PM
