outlander 2.0 turbo diesel engine ---loss of power
Old Oct 3, 2021 | 02:53 AM
  #141
Supernumber4's Avatar
Originally Posted by 2009outlander
Have you thwhad the map/boost pressure sensor changed l, I may try that and if that doesn't work I'm not going to spend anymore on it. I think it's time for us to part ways with these money pits!
I've changed everything.
Here is an updated I finally have my outlander fixed. I bit the bullet and took it to my local Mitsubishi dealer. £150 it cost and she is running perfect. I'm sure the issue is a ECU upgrade as all the parts on my car are new.
Old Oct 3, 2021 | 03:08 AM
  #142
2009outlander's Avatar
Did they tell you what the issue was? Geting fed up with mine, I've checked all the pipes related to the turbo no cracks/leaks. It's a new turbo new boost pressure sensors all new parts the mechanic has checked to nothing he's leaning to the egr valve but my egr had a blanking plate on it and an egr delete from the system so not sure if it can be that!
Old Oct 3, 2021 | 12:39 PM
  #143
They did say the vacuum pipes on the turbo where on the wrong way round but I find this hard to believe. They only had it for a day. They did say they did a SLQ. I have no idea what that is.
Old Oct 4, 2021 | 02:43 PM
  #144
I don't think the car would move much id the valves were the wrong way round! Slq no idea what that is. My mechanic is taking it to his mate who's a vw specialist as he's had enough not surprised to be honest as have I. Unfortunately the journey to my nearest Mitsubishi dealer is a hassle I don't have one near me
Old Jul 30, 2022 | 02:49 AM
  #145
Giveitago's Avatar
Default Crack in intercooler pupe
My 2017 Outlander diesel would stutter at motorway cruising speeds with no check engine light. I discovered a crack in the intercooler pipe which runs from the intercooler to the throttle body at the front of the engine. I phoned my local Mitsubishi garage who quoted £290.00 for the part. I found one for under £40 online. Fitting the pipe was quite straight forward and the problem has now gone.
Mz_jane82
Jul 23, 2021 08:08 AM
Chrisyd89
Mar 28, 2019 04:06 AM
noblesteed
Jul 5, 2013 08:34 AM
ronwill
Jun 7, 2010 11:26 AM
ash
Aug 29, 2008 10:17 AM
