Timing belt replacement
Old May 13, 2019 | 04:45 PM
OutlanderCanada's Avatar
Default Timing belt replacement
Hi Folks, I have a 2010 Outlander GT V6... 169000 km/105000 miles mileage... Can I replace the belt only...or do I have to replace water pump and tensioners too..!? I'm on a tight budget but I want the job to be done right without wasting money in unnecessary components. Thanks in advance for your valuable advise! BTW.. I'm here at Canada... Pretty expensive labor and parts!
Old May 13, 2019 | 07:12 PM
quietlymknnoise's Avatar
I suggest belt and tensioners. Most water pumps can go over 200K miles.
Old May 14, 2019 | 09:24 AM
Outlaander's Avatar
My wife and I own a 2010 V6 with about 120,000 km. It's nice to know someone got 169,000 km on the original belt, water pump, etc. Mitsubishi claims the belt should last over 169,000 and your experience proves that.
If I were you, which I will be in about 6 or 7 years, and your vehicle is relatively rust free, I'd replace just about everything including plugs. Relatively inexpensive to get another 169,000 out of your vehicle.
Good luck.
Old May 19, 2019 | 01:12 PM
ccernst's Avatar
I've had my oem belt go 105k miles and a Goodyear (now continental) go 115k miles. First time I only did belts. 2nd time I did belts, tensioner, pulleys, and water pump. Pump was perfect and no replacement was needed. Hitachi is oem and is 80 bucks from rock auto. Tensioner should have been changed the first time...was shot by 220k. Pulleys, I changed what I could...bolts were getting pretty frozen in place.
Old May 20, 2019 | 09:20 AM
Default Thanks!
Thanks for your valuable info. best!
Old May 21, 2019 | 09:03 AM
copyboy311's Avatar
I had my first timing belt change done at the Mitsubishi dealer, and they did not advise (to my surprise) changing the water pump. They did the belt and tensioner, which had a small fluid leak. I had the spark plugs replaced at the same time since the service interval is the same and the back ones on the V6 are very hard to get to.
galanturd
Mar 24, 2005 02:52 AM
speedform
Feb 25, 2005 09:00 PM
osu girl
Jan 11, 2005 03:33 PM
avachell
Sep 30, 2004 03:29 PM
cookiefan
Feb 25, 2004 11:36 AM
