Turbo troubles
Old Jan 9, 2008 | 05:06 AM
poscar's Avatar
Default Turbo troubles
Hey.Yep,another newb...(we all started somwhere)I'm getting a 4g63 to go into my 95 galant.It had a turbo on it(the motor,not the car),but it doesn't now.So,which is my best option.I know WHERE to get them,just not which 1 I need.Also,will I need a bunch of other turbo goodies too?Any help,is appreciated greatly...
Old Jan 9, 2008 | 06:34 AM
Default RE: Turbo troubles
well it depends on howmuch you want to spend. If your looking to get just the cheapest route then id go with the stock 14b turbo from the 1g eclipse's. If you want to spend more then go with a 16g. But remember you also need to mount the intercooler and all the piping. BTW did you do your research on swapping it in to make sure its a direct swap. Your also gonna need all the wiring and ECU from an eclipse, and the tranny.
Old Jan 9, 2008 | 01:28 PM
poscar's Avatar
Should be direct swap..only because of the 4g64 in it not.The trans I figured is a must to replace,but,,the intercooler,and pipe'n had slipped my mind.Thanks for reminding me.So,I hope this is all worth it in the end.
4g63-700 bux
4g63 trans-300..
trying to rebuid a sedan into a tuner..... freakin horrible!!
Old Jan 9, 2008 | 08:54 PM
lhausi2's Avatar
also be a good idea to upgrade fuel pumps, if you're going for sum power might wanna change the clutch, or if it's auto u're good
Old Jan 10, 2008 | 05:47 PM
jlh077464's Avatar
fuel pump, injectors, afpr, boost controller, wideband, tuning device. For turbo goodie upgrades that is, That I have for/sale also.
chitty024
Aug 3, 2006 04:01 PM
ictponder
Feb 20, 2006 07:26 PM
Tiberius
Sep 29, 2005 10:51 PM
o0olifeguardo0o
Apr 18, 2005 09:44 PM
DR_NO
Feb 14, 2005 11:57 PM
