Headlight problem
Old Dec 12, 2009 | 10:56 AM
sir_78's Avatar
Default Headlight problem
I have an 09 Lancer GT. Recently one of my headlights went out. When I tried replacing it I realized that it's not the bulb (as I tried two other bulbs and still nothing).
I checked fuses and all is well.
Any ideas before I have to waste my time going to dealership?
Old Dec 16, 2009 | 05:30 PM
BEAT's Avatar
I don't understand the question?
Old Dec 17, 2009 | 09:12 AM
sir_78's Avatar
Why would the right headlight not work. I have tried two other bulbs and nothing.
Old Dec 21, 2009 | 02:28 AM
Angetty09's Avatar
I wonder if anyone has had a similar problem. When I push down the headlight switch from the sidelight position, the sidelights, taillights and daash lights all go out. So I have nothing when its in headlight position, if I pull main beam it works.I have checked the fuses, they are all ok.
Old Dec 26, 2009 | 04:48 AM
Angetty09's Avatar
So my passenger side headlight is not working correctly. The low beam does not work, but the high beam works. I am assuming this is not an issue with the bulb since the high beam works. I checked the fuses and they all looked good. Anyone have any ideas as to what is wrong? Could this be a bulb problem??
Old Jan 14, 2010 | 10:42 PM
miyakayusheto's Avatar
If only one of your headlights is involved then there’s no doubt it is not in a fuse or relay. A light that is both a low beam and a high beam has two filaments. One of the filaments is probably broken. Replace the headlight and it should fix the problem. Try replacing your headlights with the right replacement headlights.
cstmgp
Sep 1, 2010 07:34 PM
panamagreen
May 2, 2007 03:24 AM
Akmikek
Jan 29, 2006 11:30 AM
Flipz
Jan 12, 2006 09:56 AM
trens
Aug 19, 2005 02:51 AM
