89 Montero engine options
Old Jul 27, 2014 | 09:36 AM
Voodoo King's Avatar
Default 89 Montero engine options
So the super nice 89 I acquired appears to need either a motor change or rebuild, what is my best option. 200k on engine that over heated and blew head gasket but as I dig into it for diagnoses it appears to have a bearing noise typical of hot engine. Do I rebuild or find replacement, is there a replacement out there, what years will interchange, or do I tear down and rebuild. Too nice a truck to scrap would really like to get back on road. it is the 3.0l v6. Any advise will help Thanks
Old Jul 27, 2014 | 01:10 PM
Akzle's Avatar
replace with a 4m series =D
the 4d55/6 and 4g series engines should bolt in, as well as the early 6g (v6) obviously.
4x4 needs 'wide block' engines, rwd are narrow block.
or rebuild with new heads and SKIM THE BLOCKS. Big end bearings arent a problem but if its damaged the crank or journals youre in for $$.
Old Jul 27, 2014 | 09:26 PM
if I am looking for a donor vehicle for engine what is the best bet?
Old Jul 28, 2014 | 01:07 AM
Akzle's Avatar
an identical one
Outie_NZ
Jan 25, 2025 05:55 AM
estalilla
Aug 19, 2011 09:52 PM
sock puppet
11
Sep 23, 2009 08:05 AM
downhillspec
Mar 31, 2009 08:33 AM
off roader
Oct 24, 2006 07:51 PM
