HELP! With 07 xls radiator leak
Old Oct 12, 2020 | 01:14 PM
  #21
copyboy311's Avatar
Now that part, I'm not sure is replaceable. The seam on that side of the radiator is where mine took a dump, and the whole thing had to be replaced. You may be experiencing the same thing, a seam break. Seeing that yours is a 2007 also, I'm guessing the radiator is probably done. Plastic fatigues over time, and it's now 13 years old.
Old Jan 4, 2023 | 12:10 PM
  #22
tvguy2005's Avatar
Just for future reference that might help others with DOR/PZEV radiators, I saw you post in this other thread where I posted my solution so hopefully you are all set but all I did was solder a wire jumper across all 4 contacts, 2 on each side, routing the wire around the back of the sensor so that the car will think it's still installed properly. See here for more: https://mitsubishiforum.com/forum/mi...able-us-48069/
Derrick Jones
Oct 3, 2018 08:06 AM
xiaomeng88
Jul 31, 2017 11:52 AM
Dan Dossey
Apr 4, 2015 09:53 PM
TheRock0720
Nov 12, 2010 12:30 PM
adro1982
Jun 24, 2007 04:02 PM
