Troubles
Old Oct 15, 2009 | 02:33 PM
4G63Evo's Avatar
Default Troubles
I have a 96 eclipse gs 5 speed. Recently I was driving it when it started to lose power i pushed the gas a little more then it began to shake as if it were trying to push with all of its might then finally cut off. When i tried to cut it back on it turned on fine without hesitation. Again,today the same shaking happened but without turning off i then noticed that every one in a while my rpm needle would drop very low almost stall then shoot back up very frequently what could be the problem??
Old Oct 17, 2009 | 09:23 AM
01Spyderman's Avatar
Not sure if it could be the same cause, but I have a 2001 Eclipse that had the same problem. Before changing the IAC valve, I had the throttle body checked out and cleaned. Sometimes deposits build up and it's almost like a "choke". Cleaning the throttle body and air filter fixed it for me. Hope it works for you, since it didn't cost much. IAC would have run almost $400.
chitty024
Aug 3, 2006 04:01 PM
ictponder
Feb 20, 2006 07:26 PM
Tiberius
Sep 29, 2005 10:51 PM
o0olifeguardo0o
Apr 18, 2005 09:44 PM
DR_NO
Feb 14, 2005 11:57 PM
